*beams_to_surfaces
Create surfaces/meshes from 1D beams.
*beams_to_surfaces entitytype=<value> mark=<value> <option1>=<value1> <option2>=<value2> ... <optionN>=<valueN>
HyperMesh Tcl Modify Command
Create surfaces/meshes from 1D beams. The beams must have valid section data assigned.
- domesh=<value>
- Specifies whether the generated surfaces should be meshed:
- dosnap=<value>
- Specifies whether the generated surfaces should be snapped at the surface intersection within snaptol:
- entitytype=<value>
- The type of input 1D entities. Valid values are elements and components. This is a mandatory option.
- mark=<value>
- The ID of the mark of input entities. Valid values are 1 and 2. This is a mandatory option.
- meshextension=<value>
- Specifies whether the generated mesh should be extended to the connected surfaces:
- meshsize=<value>
- The size of the mesh when domesh=1. The default is the global element size.
- meshtype=<value>
- Specifies the mesh element type when domesh=1:
- stitchtol=<value>
- The stitch tolerance when dosnap=1. The default is the global geometry cleanup tolerance.
- tobeamcomponent=<value>
- Specifies the surface/mesh component organization:
- usebeamnode=<value>
- Specifies whether the generated surfaces and mesh should be congruent to the base mesh:
Examples
*beams_to_surfaces entitytype=elems mark=1 usebeamnode=1 meshextension=1 dosnap=1 domesh=1 meshsize=100 meshtype=2 stitchtol=0.0 tobeamcomponent=1 Errors
# Handle error
}Version History
2021
