*solid_cavity_detect_modify_rims
Modify a partially detected cavity by adding and removing rims.
*solid_cavity_detect_modify_rims add_mark_id remove_mark_id region_id add_surfs_flag
HyperMesh Tcl Modify Command
The command *solid_cavity_detect_start must be called before calling this command to generate the cavities as region entities.
- add_mark_id
- The ID of the mark containing edges to add as rims. Valid values are 1 and 2.
- remove_mark_id
- The ID of the mark containing existing edges to remove as rims. Valid values are 1 and 2.
- region_id
- The ID of the region containing the cavity definition to modify.
- add_surfs_flag
- 1 - The extracted surfaces are added to the cavity.
Examples
Add a rim represented by a connected set of surface edges with IDs 3 and 4 with a cavity represented by region ID 10,and remove the rim represented by surface edge IDs 7 and 8. Add the surfaces, as the volume of cavity increases due to this modification:
*createmark lines 1 3 4
*createmark lines 2 7 8
*solid_cavity_detect_modify_rims 1 2 10 1
# Handle error
}Version History
2019
