*set_acousticmesh_options
Assigns certain options used during acoustic cavity meshing.
*set_acousticmesh_options string_array number_of_strings
HyperMesh Tcl Modify Command
- string_array
- The ID of the string array that contains the option parameters. The string array is created using the *createstringarray command. This should always be set to 1.
- number_of_strings
- Integer indicating the size (number of strings) in the string array created using *createstringarray.
TBD
*createstringarray 3 "NumElemPerWaveLength: 6" "WaveSpeed: 31000" "DisplayCavities: 10"
*set_acousticmesh_options 1 3
# Handle error
}Version History
14.0
