*elempatchstartaction
Starts the QI patch checker.
*elempatchstartaction patch_type threshold
HyperMesh Tcl Modify Command
This command only functions between an *elementqualitysetup command and an *elementqualityshutdown command.
- patch_type
- Must be set to 0.
- threshold
- Threshold value for the element quality:
- 0.8 - Warning elements
- 1.0 - Failed elements
- 10.0 - Worst elements
*readqualitycriteria c:/criteria/mycriteria.txt
*createmark elems 1 displayed
*elementqualitysetup 1
*elempatchstartaction 0 1.0
*elempatchnextaction
*elempatchincraction
*elempatchprevaction
*elempatchdecraction
*elempatchstopaction
*elementqualityshutdown 1Errors
# Handle error
}Version History
13.0
