*CE_Unrealize
FE unrealize all the defined connectors on mark (removes all created FE).
*CE_Unrealize mark_id
HyperMesh Tcl Modify Command
- mark_id
- The mark of connectors that needs to be unrealized.
Examples
*createmark connectors 1 1 2
*CE_Unrealize 1This command should be called only after the *CE_FE_SetDetails command. The connector state is set to unrealized and the connectors are displayed in yellow.
