*swapcards
Swaps the card image of an entity.
*swapcards entity_type mark_id ?target_card_image?
HyperWorks Tcl Query Command
- In OptiStruct, it is used to swap groups CONTACT and TIE.
- In Samcef, it is used to swap groups MCT and STI. New master and slave entities are created on swapping based on the entity types supported specific to element type and contact type.
- entity_type
- The type of entity to update. Must be set to groups.
- mark_id
- The ID of the mark containing the groups to update. Valid values are 1 and 2.
- target_cardimage
- The target card image to which the entity need to be swapped. If not specified, a default mapping is done.
To swap Samcef MCT contacts with IDs 1 and 2:
*createmark groups 1 1 2
*swapcards groups 1
# Handle error
}Version History
14.0.130
