*elementsaddelemsfixed
Marks the specified 1D plot elements as feature edges before using the command for remeshing by elements.
*elementsaddelemsfixed mark_id
HyperMesh Tcl Modify Command
This command changes the densities of selected surface edges and remeshes the adjacent surfaces, according to the specified mode. This is an automesh function.
- mark_id
- The mark ID containing 1D plot elements that should be considered to form feature edges in the subsequent element remesh operation.
*createmark elems 1 "displayed"
*setusefeatures 1
*createmark elems 2 1600-2220
*elementsaddelemsfixed 2
*defaultremeshelems 1 3.0 2 2 0 1 1 1 0 0 0 0 0 30Errors
# Handle error
