*pressuresonentity_curve
Creates a pressure load on a mark of elements, surfaces, components or sets, potentially with its magnitude defined by a curve.
*pressuresonentity_curve entity_type mark_id facenodes x_comp y_comp z_comp magnitude breakangle onface xlocation ylocation zlocation curve_id x_scale
HyperMesh Tcl Modify Command
- entity_type
- Type of entity the load is applied on. (e.g. surfs or elems).
- mark_id
- The ID of the mark of entities on which to apply the pressure.
- facenodes
- The ID of the mark containing nodes that lie on the face of one or more elements (solids only).
- x_comp
- The x-component of pressure.
- y_comp
- The y-component of pressure.
- z_comp
- The z-component of pressure.
- magnitude
- The magnitude of the pressure.
- breakangle
- The break angle of a solid face.
- onface
- A logical which determines whether pressures are being applied to faces:
- xlocation, ylocation, zlocation
- For loads on components or sets, you may wish to supply a display location for where HyperMesh should draw the graphical image for the load. If these three values are 999999, or more than one entity is selected, HyperMesh will generate a display location from the contents of the components or sets.
- magnitude
- curve_id
- The ID of a curve defining the magnitude of the load vs time.
- x_scale
- A scale factor applied to the x-axis (or time axis) of the curve.
To apply a pressure of 4 to the elements of a component, using the curve with ID 9 to vary this magnitude over time:
*createmark(components,1) "container"
*createmark(nodes,1)
*pressuresonentity_curve(comps,1,1, 0,0,0, 4,30,1, 0,0,0, 9, 1.0)
# Handle error
}Version History
2021 - Added onface values 10, 11, 20, 21, 30 and 31.
