*linemarkbypath
Creates a line path from the starting line to the ending line.
*linemarkbypath line_id1 line_id2 mark_id flag
HyperMesh Tcl Modify Command
- line_id1
- The ID of the first line.
- line_id2
- The ID of the second line.
- mark_id
- The ID of the line mark to populate. Valid values are 1 and 2.
- flag
- 0 - If both line_id1 and line_id2 lie are free edges, the path will follow free edges where possible. Otherwise, the shortest path is returned.
To determine the path between lines 100 and 110 using the shortest path:
*linemarkbypath 100 110 1 1
# Handle error
}Version History
11.0.101
