*find_holes_in_3d_body
*find_holes_in_3d_body entity input_mark output_mark mode flags min_diam max_diam max_lensize
HyperMesh Tcl Modify Command
- entity
- The entity type in which the holes reside. Valid options are surfs and solids.
- input_mark
- A mark containing the desired surfaces or solids.
- output_mark
- A mark that will contain the surfaces recognized as sides of the holes in 3D body.
- mode
- Selects the search algorithm to use (see the comments section below for known
limitations of each mode):
- 1 - Recognize all circular holes passing through the entire solid. Recognizes filleted ends/rims. Ignores all other parameters.
- 2 - Recognize elongated or circular holes that do not pass through the entire solid. Does not recognize holes with filleted ends/rims.
- flags
- Sets a filter for the shape of holes to be recognized:
- 0 - No filtering (arbitrary shapes allowed).
- 1 - Only round holes are found.
- 2 - Only rounded slots are found.
- 3 - Round holes and round slots are found.
- min_diam
- Smallest diameter of holes to be found.
- 0 - No limit
- max_diam
- Largest diameter or width of the holes to be found.
- 0 - HyperMesh uses no upper limit.
- max_lensize
- Maximum length for elongated holes/slots.
- 0 - To allow any length (no limit).
*find_holes_in_3d_body (surfaces 1 2 1 0 0 0 0)*find_holes_in_3d_body (surfaces 1 2 2 1 1 5 10)Mode=1 does not utilize the arguments for flags, min_diam, max_diam, and max_lensize. Thus, these are each treated as being zero.
Mode=2 utilizes all arguments, but only locates holes with sharp edges.
