*createentitysameas
Create a new entity that is a clone of a source entity.
*createentitysameas entity_type entity_id
HyperMesh Tcl Modify Command
Create a new entity that is a clone of the original. Attributes and data names are both cloned, however, collected entities are not cloned along with collectors.
- Rigid wall entities are not supported.
- entity_type
- Entity type to use as source.
- entity_id
- The ID of the source entity to clone.
Examples
*createentitysameas comps 100Errors
# Handle error
}Version History
13.0
