*CE_PreviewBoltCylinder
Set cylinder bolt parameters for bolt connectors and display the graphical preview.
*CE_PreviewBoltCylinder mark_id solver_name config fe_config tolerance options options_size
HyperMesh Tcl Modify Command
This command sets cylinder bolt parameters for bolt connectors and displays the graphical preview.
- mark_id
- The ID of the mark containing the connectors to update. Valid values are 1 and 2.
- solver_name
- The name of the solver to query. Examples include: Nastran, Abaqus, LS-DYNA, etc.
- config
- The connector config. Must always be set to 1001 at the present time.
- fe_config
- The FE element config.
- tolerance
- The realization tolerance.
- string_array
- The ID of the string array that contains the additional input parameters. The string array is created using the *createstringarray command. This should always be set to 1.
- number_of_strings
- Integer indicating the size (number of strings) in the string array created using *createstringarray.
Examples
*createmark connectors 1 1 2 3
*createstringarray 9 "ce_notuseijk=1" "ce_diameter=2.000000" "ce_l1d1=1.000000" "ce_l2d2=1.000000" "ce_l1=5.000000" "ce_l2=5.000000" "ce_bodylen=-1.000000" "ce_passthroughce=0" "ce_dia_factor=1.000000"
*CE_PreviewBoltCylinder 1 "nastran" 1001 60 10.0 1 9Errors
# Handle error
}Version History
13.0
