*CE_FE_GlobalFlags
Set global flags for connectors to perform different operations.
*CE_FE_GlobalFlags ce_fe_flag function
HyperMesh Tcl Modify Command
- ce_fe_flag
- 0 - false
- function
- A function value of (0) sets the global flag to delete FE with connectors. If ce_fe_flag is true, the realized FE is deleted with connectors. If it is false, then only connectors are deleted.
Examples
*createmark(connectors, 1) 1 2 3
*CE_FE_GlobalFlags(1, 0)
*deletemark(connectors, 1)When trying to delete FE with connectors, this command needs to be called before the connector delete function.
