*CE_MarkRemoveLink
Remove a link entity of a specific type and ID or name from the connectors on mark.
*CE_MarkRemoveLink ce_mark option linktype link_id link_name
HyperMesh Tcl Modify Command
- ce_mark
- Mark of connectors.
- option
- Specifies if all the links in the connector or a specific link needs to be removed.
- 0 - Remove all links in the connector.
- 1 - Remove the link specified by type and ID/name.
- linktype
- Specific link type to search in the connector. If link ID/name is not specified, the first link found with the same type defined by proximity rule is removed.
- link_id
- Link ID to remove from connector. This is optional, if the name is specified.
- link_name
- Link name to remove from the connector. This is optional, if the ID is specified.
Examples
*createmark connectors 1 "displayed"
*CE_MarkRemoveLink 1 0 0 0 ""*createmark connectors 1 "displayed"
*CE_MarkRemoveLink 1 1 comps 10 ""
