*morphmaptoequationvecoffset
Maps nodes to the surface of an equation along a vector.
*morphmaptoequationvecoffset entity_type_nodes mark_id_nodes entity_type_handles mark_id_handles equation origin origin_id use_symmetry use_constraints project vector_id mode offset
HyperMesh Tcl Modify Command
Maps nodes to, or offset from, an equation using the temporary shape created by *morphmaptshp and *morphmaptshpedge as a guide. Selected handles can optionally follow behind the morphing operation.
Nodes can be projected on to the equation along a vector, normal to the surface of the equation, or normal to the shell elements attached to the nodes.
- entity_type_nodes
- Must be set to nodes.
- mark_id_nodes
- The ID of the mark containing the nodes. Valid values are 1 and 2.
- entity_type_handles
- Must be set to handles.
- mark_id_handles
- The ID of the mark containing any following handles. Valid values are 1 and 2.
- equation
- String containing an equation f(x,y,z). The equation can contain x, y, and z variables but should not contain an equals sign. The surface of the function is located where the value of the function equals zero.
- origin
- 0 - Use global origin and system
- origin_id
- The ID of node or system specified in origin. Ignored if origin is 0.
- use_symmetry
- 0 - Do not use symmetry links
- use_constraints
- 0 - Do not use constraints
- project
- 0 or 10 - Project along vector defined by vector_id
- vector_id
- The ID of vector created using *createvector for the projection direction. Must be set to 1.
- mode
- 0 - If *morphmaprecalc has been used to calculate new influences
- offset
- The distance to offset nodes from the target.
Examples
To map all nodes to a sphere of radius 10.0 with an offset of 1.2, when not using *morphmaprecalc:
*createmark nodes 1 "all"
*createmark handles 1
*createvector 1 1.0 0.0 0.0
*morphmaptoequationvecoffset nodes 1 handles 1 "x*x+y*y+z*z-100.0" 0 0 1 1 1 1 1 1.2
To map all nodes to a sphere of radius 10.0 positioned at a system along a vector:
*morphmaptoequationvecoffset nodes 1 handles 1 "x*x+y*y+z*z-100.0" 2 1 1 1 0 1 1 0.0
# Handle error
}Version History
14.0.110
