*element3Dshiftnodes
Reorders the nodes in a 3D element.
*element3Dshiftnodes element_id_3D mode shift_value first_node_id last_node_id second_node_id element_id_2D
HyperMesh Tcl Modify Command
Reorders the nodes in 3D elements based on various modes.
- element_id_3D
- The 3D element ID to reorder.
- node
- Determines how the nodes are reordered.
- 1 - Reorder the nodes as defined by the shift_value argument (2 digit value).
- 2 - Reorder the nodes defined by 3 nodes in the 3D element. The first_node_id, last_node_id and second_node_id arguments define the new base face.
- 3 - Reorder the nodes by referencing a face element defined by the element_id_2D argument.
- 4 - Reorder the nodes as defined by the shift_value (1 digit value) and first_node_id arguments.
- shift_value
- When mode is 1, this is a 2 digit integer. The first digit defines the element’s new base face index, while the second defines the index of the new first node for that face.
- first_node_id
- Defines the first node in the reordered 3D element, when mode is 2.
- last_node_id
- Defines the last node in the reordered 3D element base face, when mode is 2.
- second_node_id
- Defines the second node in the reordered 3D element base face, when mode is 2.
- element_id_2D
- The 2D element ID to use as the base face for the reordered 3D element. The first node of this 2D element becomes the first node of the 3D element.
*element3Dshiftnodes 213 1 31 0 0 0 0*element3Dshiftnodes 213 2 0 137 138 139 0*element3Dshiftnodes 213 3 0 0 0 0 94*element3Dshiftnodes 213 4 3 94 0 0 0Errors
# Handle error
