*CE_EditSeamAndLineDetail
Edit density, spacing and offset details for seam or line spot connectors specified by mark.
*CE_EditSeamAndLineDetail ce_markmask density spacing half_spacing_offset offset param1 param2
HyperMesh Tcl Modify Command
- ce_markmask
- The mark of connectors that needs to be updated.
- density
- Integer number to split line into number of points. Spacing between points (= line_length/density).
- spacing
- Float number to split line into number of points with specified distance between points (= spacing).
- half_spacing_offset
- Create points from an offset (= spacing/2) from the start and end of line ().
- 0 = true
- 1 = false
- offset
- Create points from an offset (= offset) from the start and end of line.
- param1
- For future use (must be 0).
- param2
- For future use (must be 0.0).
Examples
*createmark(connectors, 1) 1 2 3
*CE_EditSeamAndLineDetail(1, 10, 0.0, 0, 1.5, 0, 0.0)The specified details are modified, only if the previous values were not the same. The modified connectors are unrealized since editing details affects realization.
This command is outdated. *CE_DetailSetInt() and *CE_DetailSetDouble() are recommended for the purpose of setting details for a seam connector.
