*morphconstraintcreateedge
Creates a tangency constraint between two edge or 2D domains or for a single edge domain.
*morphconstraintcreateedge name dptr1 dptr2 end type vec color
HyperMesh Tcl Modify Command
This command creates a tangency type constraint either between two edge domains or 2D domains or at the end of one edge domain. For the master type, dptr1 is the master and dptr2 is the slave. For the slave type, dptr2 is the master and dptr1 is the slave. For the attached type, dptr1 follows dptr2.
- name
- The name of morph constraint.
- dptr1
- The ID of the edge or 2D domain.
- dptr2
- end
- The ID of node at fixed end (for fixed type).
- type
- 1 - Fixed (edge domains only)
- vec
- The ID of the vector created using *createvector. Must be set to 1.
- color
- The color of the constraint. Valid values are 1 through 64.
To create a continuous tangency constraint named "tang" between domains 12 and 14:
*createvector 1 1.0 0.0 0.0
*morphconstraintcreateedge "tang" 12 14 1 4 1 44
To create a master tangency constraint named "master" where domain 14 is forced tangent to domain 12:
*morphconstraintcreateedge "master" 12 14 1 2 1 44
# Handle error
}Version History
9.0
