*CE_DetailSetUintByMark
Sets an unsigned integer as connector detail for a connector specified by ID.
*CE_DetailSetUintByMark markmask detailName uint_val unknownFlag force_storage_flag
HyperMesh Tcl Modify Command
- markmask
- Mark containing the connectors to attach details to.
- detailName
- Name for a user-defined unsigned integer detail.
- unit_val
- The unsigned integer value for the detail.
- unknownFlag
- Reserved for future use. Must be set to 0.
- force_storage_flag
- The flag indicating whether or not to store a user-defined detail.
- 1 = yes
- 0 = no
Examples
*createmark(connectors, 1) 1, 2, 3, 4
*CE_DetailSetUintByMark(1, "test", 2.0, 0, 1)There are currently no standard unsigned integer details, only user-defined ones.
