*tablepopulate
Populates a table with data from a delimited file.
*tablepopulate name filename delimiter
HyperMesh Tcl Modify Command
Populates an existing table with data from a delimited file. The data in the file must match the format of the columns defined in the table. Additional rows are appended to the table and existing data remains.
- name
- The name of the table to populate. The table will be overwritten with the data from the file.
- filename
- The full path and filename of the file to use to populate the table.
- delimiter
- The character or string to use as the delimiter. The value must be enclosed in quotes. If not specified, the default is a comma (CSV).
Examples
To populate table1 with C:/table1.csv, which is a comma delimited file:
*tablepopulate table1 C:/table1.csv ","
or
To populate table1 with C:/table1.txt, which is a space delimited file:
*tablepopulate table1 C:/table1.txt " "
# Handle error
}Version History
11.0
