*GetLatitudeLineHandles
Finds the latitude lines handles of the selected latitude lines and shows these handles in HyperMesh.
*GetLatitudeLineHandles entity_type1 mark_id1 entity_type2 mark_id2 selection_type
HyperMesh Tcl Modify Command
This command finds and shows in HyperMesh the handles of latitude lines stored into mark_id1. Valid entity_type1 value for latitude lines is LINES, and valid selection_type value is 1. If you want to see the handles of a latitude lines group, you need to select two ribs that are stored into mark_id2. Valid entity_type2 value for ribs is LINES and valid selection_type value is 2.
- entity_type1
- Entity type LINES.
- mark_id1
- Mark ID. It can be 1 or 2.
- entity_type2
- mark_id2
- selection_type
- Integer value.
- 1 - For single latitude lines selection.
- 2 - For group latitude lines selection.
*createmark lines 1 1418 1419 1550
*createmark lines 2
*GetLatitudeLineHandles lines 1 lines 2 1 *createmark lines 1 1418
*createmark lines 2 1344 1335
*GetLatitudeLineHandles lines 1 lines 2 2 Errors
# Handle error
