*surfacestringcreatemidline
Creates midlines for strings of narrow surfaces (fillets, rib tops, etc...).
*surfacestringcreatemidline mark_id ?<option1>=<value1>? ?<option2>=<value2>? ... ?<optionN>=<valueN>?
HyperMesh Tcl Modify Command
Creates midlines for strings of narrow surfaces (fillets, rib tops, etc...). The command takes as input a mark of surfaces that can be interpreted as narrow strings sets : one or several disconnected strings. Optionally configuration of string could be additionally supported with given mark of the strings long sides lines. The result of the command – topological midlines created for each of the surfaces strings. The result surfaces are placed on the imput mark. Optionally the created midlines could be marked by a given output mark. The optional parameters of the command are in “key-value” format. The options order and number is arbitrary
- mark_id
- The ID of the mark of narrow surfaces. Valid values are 1 and 2.
- alonglines_mark=<value>
- The ID of a mark containing the along side lines. Valid values are 1 and 2. If empty (default), the lines are auto-calculated.
- midlines_outmrk=<value>
- The ID of the mark of output midlines. Valid values are 1 and 2. If empty (default), the output midlines are not placed on a mark.
Examples
*createmark surfaces 1 7054-7077
*surfacestringscreatemidline 1*createmark surfaces 1 7054-7077
*surfacestringscreatemidline 1 midlines_outmrk=2Errors
# Handle error
}Version History
2021
