*acousticmeshinit
Initializes an acoustic cavity mesh before running *acousticmeshinit.
*acousticmeshinit structural_mark_id seats_mark_id cell_size seat_coupling topo_patch_size semantic_patch_size create_hole_elements flag reserved
HyperMesh Tcl Modify Command
Used to initialize an acoustic cavity mesh. This command must be run before *acousticmeshcreate, which actually generates the preview and solid acoustic cavity meshes.
- structural_mark_id
- The mark ID containing any input structural comps. Valid values are 1 and 2.
- seats_mark_id
- The mark ID containing any seat comps. Valid values are 1 and 2.
- cell_size
- The element size of the solid elements.
- seat_coupling
- A flag used to denote:
- topo_patch_size
- The input (topological) hole patch size.
- semantic_patch_size
- The input (semantic) hole patch size.
- create_hole_elements
- A value of 1 indicates to create patch elems to topo holes. These elements are places in the ^patches_holes component.
- flag
- Reserved for future use. Must be specified as 0.
- reserved
Examples
To initialize an acoustic cavity mesh with an element size of 40.0, patching holes and gaps of 200.0 and 100.0 respectively, and creating the hole patch elements:
*acousticmeshinit 1 2 40.0 0 200.0 100.0 1 0 0
# Handle error
}Version History
10-SA1-110
