*wadlines_hardpartzone
Creates the hard part zone by duplicating and trimming the vehicle outer components with test zone boundaries.
*wadlines_hardpartzone entity_type mark_id double_array number_of_doubles vector_id search_distance
HyperMesh Tcl Modify Command
- entity_type
- The type of entity for the vehicle outer. Must be set to comps.
- mark_id
- The ID of the mark of vehicle outer components. Valid values are 1 and 2.
- double_array
- The double array ID that contains the 3D coordinates of the vertices defining the test zone. The double array is created using the *createdoublearray command. This should always be set to 1.
- number_of_doubles
- Integer indicating the size (number of doubles) in the double array created using *createdoublearray. This should be 3 times the number of spheres.
- vector_id
- The ID of a vector created using the *createvector commend. This vector defines the perpendicular direction of the test zone, used to search elements within the test zone up to the search_distance. Valid values are 1 and 2.
- search_distance
- The perpendicular distance from the test zone boundary used to select elements from the vehicle outer components.
Examples
To create a hard part zone around the displayed components with a tolerance of 10:
*createvector 1 0 0 1
*createdoublearray 12 1343.514343661 709.91761797527 973.43251742578 1334.7036682323 703.07456401521 973.15886027621 1327.8482379749 697.4142871779 972.93366355648 1323.86674249 694.00118686161 972.79787178914
*createmark comps 1 displayed
*wadlines_hardpartzone comps 1 1 12 1 10
# Handle error
}Version History
2021
