hm_wadlinessetfrontentitiesforcollision
Sets the front entities to be used to create the bonnet rear reference line.
hm_wadlinessetfrontentitiesforcollision entity_type mark_id
HyperMesh Tcl Query Command
BRRL spheres are rolled on the windscreen to collide with the front entities of the vehicle. Points of contact of these spheres with the front entities are used to construct the BRRL.
This API must be used after initializing the wadlines analysis using hm_wadlinesinit.
- entity_type
- The type of entities being set for collision. Valid values are comps.
- mark_id
- The ID of the mark containing the entities set for collision. Valid values are 1 and 2.
Examples
To set the front entities for collision to comps 102 and 103:
*createmark comps 1 102 103
hm_wadlinessetfrontentitiesforcollision comps 1
# Handle error
}Version History
2020
