hm_ce_getprojcompid
Returns the component ID for the projection data layer of interest.
hm_ce_getprojcompid index layer
HyperMesh Tcl Query Command
- index
- The index of interest in the array (corresponds to a weld).
- layer
- The independent (= 1) or the dependent (= 0) layer the weld connects.
To get the component ID for index 5 and independent layer:
set comp_id [ hm_ce_getprojcompid 5 1];This function should only be called from within a connector-registered property script (which is executed during connector FE realization). The projection data this function relies upon is removed immediately after connector FE realization.
The component corresponds to the part the weld is connecting at that location.
