hm_setmodelcheckcorrectionstatus
Sets the applied status for the specified Model Check correction display name.
hm_setmodelcheckcorrectionstatus display_name display_name_correction status
HyperMesh Tcl GUI Command
- display_name
- The check display name.
- display_name_correction
- The correction display name.
- status
- 0 - Not applied
- 1 - Applied
- 2 - Partially applied
To set the applied status for the check named "Unused Materials" and correction named "Delete Unused Materials" to applied (1):
hm_setmodelcheckcorrectionstatus "Unused Materials" "Delete Unused Materials" 1
# Handle error
}Version History
11.0.101
2019 - Added new status value 2.
