hm_ce_getvalidabsolutepath
Returns a valid absolute path from a relative path.
hm_ce_getvalidabsolutepath relative_path
HyperMesh Tcl Query Command
Returns a valid absolute path from a relative path. Returns an empty string if the relative path could not be converted into a valid absolute path.
- relative_path
- The relative path of the file/folder. Supported relative path tags:
To get the absolute path for the user home relative path:
hm_ce_getvalidabsolutepath {[USER_HOME]/Some_Folder/Some_File.txt}
Returns: {C:/Users/username/Some_Folder/Some_File.txt}Errors
   # Handle error
}Version History
14.0.110
