hm_gethmfileversion
Returns the binary file version string for a specified HyperMesh database.
hm_gethmfileversion filename
HyperMesh Tcl Query Command
- major is the major file version. It is itself comprised of two parts, release.binary.
- minor is the minor file version.
- filename
- The full path and filename of the database file. Paths with spaces must be enclosed in quotes.
To get the file version for C:\temp\test.hm:
hm_gethmfileversion C:/temp/test.hm
# Handle error
}Version History
13.0.110
