hm_getmeshedgeparams
Returns all of the relevant automesh settings applied to that surface edge.
hm_getmeshedgeparams edge_id
HyperMesh Tcl Query Command
This command returns all of the relevant automesh settings applied to a surface edge by *set_meshedgeparams. If no automesh settings are applied, no values are returned. The returned values are (in order):
- elem_density
- alg_type
- bias_style
- bias
- min_size
- max_size
- chordal_dev
- max_angle
- edge_id
- The global edge ID of the surface edge to query.
To get the automesh parameters assigned to edge with ID 15:
hm_getmeshedgeparams 15
# Handle error
}Version History
10.0
