hm_attributetype
Returns the attribute type number of an attribute for the current template.
hm_attributetype attribute_name_or_id
HyperMesh Tcl Query Command
- 1 - integer
- 2 - double
- 3 - string
- 4 - 1D integer array
- 5 - 1D double array
- 6 - entity
- 7 - (not supported)
- 8 - (not supported)
- 9 - 2D integer array
- 10 - 2D double array
- 11 - string array
- 12 - 1D entity array
- 13 - 2D entity array
- attribute_name_or_id
- The name or ID of the attribute to query. The attribute must be in the current template.
Examples
To get the attribute type number of the attribute named LSD_PID for the LS-DYNA template:
hm_attributetype LSD_PIDTo get the attribute type number of the attribute ID 149 for the LS-DYNA template:
hm_attributetype 149Errors
   # Handle error
}Version History
10-SA1-110
