hm_attributestatus
Returns the status flag of an attribute on an entity for the current template.
hm_attributestatus entity_type entity_name_or_id attribute_name_or_id ?search_type?
HyperMesh Tcl Query Command
Returns the status flag of an attribute on an entity for the current template. If the attribute does not exist on the entity, or is not an attribute from the current template, an error is returned.
- entity_type
- The type of entity to query.
- entity_name_or_id
- The name or ID of the entity.
- attribute_name_or_id
- The name or ID of the attribute to query. The attribute must be in the current template.
- search_type
- By default, HyperMesh searches for entities by name, and if the name is not found, it then searches by ID. This option allows you to specify how the search for an entity should be conducted. Valid values are:
Examples
To get the attribute status of the attribute named Rho on material 6 for the LS-Dyna template:
hm_attributestatus material 6 Rho -byid
To get the attribute status of attribute ID 118 on material 6 for the LS-Dyna template:
hm_attributestatus material 6 118 -byid
# Handle error
}Version History
10-SA1-110
