hm_flangedetectionend
Clear memory and ends the flange detection module.
HyperMesh Tcl Query Command
Clears memory and ends the flange detection module. This must be preceded by any calls to hm_flangedetectioninit and other hm_flangedetection* APIs.
"Major" database changes made while inside of the flange detection module will invalidate and delete any results.
Examples
To find 2D flanges from elements in all components, using a min width of 2, a max width of 20 and a feature angle of 20, and write out all flange details to a file named C:/temp/flanges.txt:
set flangesfile [open "C:/temp/flanges.txt" "w"]
*createmark comps 1 all
hm_flangedetectioninit comps 1
hm_flangedetectionsetparams min_width=2.0 max_width=20 feature_angle=20
hm_flangedetectionfindflanges 1
set n [hm_flangedetectiongetnumberofflanges]
if { $n > 0 } {
puts $flangesfile "Number of flanges = $n"
puts $flangesfile "Flanges details"
for {set i 0} {$i < $n} {incr i} {
puts $flangesfile "$i details = [hm_flangedetectiongetflangedetails $i]"
puts $flangesfile "$i midline = [hm_flangedetectiongetflangemidline $i offset_dist=0]"
hm_flangedetectionfindmates min_search_dist=0 max_search_dist=10
set m [hm_flangedetectiongetnumberofmatinggroups]
if { $m > 0 } {
for {set i 0} {$i < $m} {incr i} {
puts $flangesfile "$i = [hm_flangedetectiongetmatinggroupdetails $i]"
} else {
puts $flangesfile "Flange mates not detected."
} else {
puts $flangesfile "Flanges not detected."
close $flangesfile
# Handle error
}Version History
2019
