hm_issurfacemappable
Checks whether the given surface can be mapped or not and returns the map shape and vertices of the shape.
hm_issurfacemappable surface_id element_size
HyperMesh Tcl Query Command
The output consists of an integer defining the map shape, and a list of vertices for map shapes other than circular.
0 - If the shape is not mappable
1 - If the map shape is triangular
2 - If the map shape is rectangular
3 - If the map shape is pentagonal
4 - If the map shape is circular
- surface_id
- The ID of the surface to query.
- element_size
- The element size of interest for the surface.
Examples
To check if surface 1 is mappable with size 2.5:
hm_issurfacemappable 1 2.5
2 {10 13 12 11}
# Handle error
}Version History
2019
