hm_comparegettransformationmatchentities
Returns the entity IDs associated with a specific transformation and match.
hm_comparegettransformationmatchentities transformation_index match_index match_location
HyperMesh Tcl Query Command
Returns the entity IDs associated with a specific transformation and match. This must be preceded by a call to a relevant hm_compareentities* command.
- transformation_index
- The index of the transformation to query, starting with 0. The number of transformations can be found using hm_comparegettransformationcount.
- match_index
- The index of the match corresponding to the transformation_index to query, starting with 0. The number of matches can be found using hm_comparegettransformationmatchcount.
- match_location
- The location of the match to query. Valid values are:
To find the source entity IDs for transformation 0 and match 5 for the recursive comparison of surfs 1-20 and 101-120:
*createmark surfs 1 1-20
*createmark surfs 2 101-120
hm_compareinit
hm_compareentitiesrecursive surfs 1 surfs 2 0.1 2 0
set source_entities [hm_comparegettransformationmatchentities 0 5 1]
hm_compareend
# Handle error
}Version History
12.0
