hm_modelchecksavetoxml
Saves the config data to an XML file.
hm_modelchecksavetoxml filename
HyperMesh Tcl Query Command
Saves the config data (checks and corrections) for the current profile to an XML file.
- filename
- The full name and path of the XML file to save.
Examples
To save the current profile checks and corrections to C:\temp\my_config.xml:
hm_modelchecksavetoxml C:/temp/my_config.xml
# Handle error
}Version History
2019
