hm_getelemcheckbounds
Returns the lower and upper bound values of the specified element check from the selected elements.
hm_getelemcheckbounds mark_id dimension check_type ?time_failure?
HyperMesh Tcl Query Command
This command returns the lower bound and upper bound values of the specified element check from the selected elements. Only the elements on mark_id and of the specified dimension are considered when calculating the lower and upper bound values.
- mark_id
- The ID of the mark containing the elements. Valid values are 1 and 2.
- dimension
- The dimension of the elements on mark_id to consider. Valid values are:
- check_type
- The type of element check to return the bounds from. The allowable values depend on the dimension specified:
- ?time_failure?
- The value to use as a threshold beyond which the input elements should be considered to have failed the test. This is required only when check_type is set to addedmass.
Examples
To get the min and max length of all displayed 1D bar elements:
*createmark elems 1 "by config" bar
*createmark elems 2 displayed
*markintersection elems 1 elems 2
foreach {lower upper} {[hm_getelemcheckbounds 1 1 length]} {}
To get the lower and upper length values for all first order 2D elements:
*createmark elems 1 "by config" tria3 quad4
foreach {lower upper} {[hm_getelemcheckbounds 1 2 length]} {}
# Handle error
}Version History
10.0
2019 - Added new check_type values minlength and maxlength for both 2D and 3D, and ortho_3d and size_ratio_3d for 3D.
