hm_ce_generatenamefromsubsystem
Returns a name using a base name and connector subsystem ID.
hm_ce_generatenamefromsubsystem id base_name
HyperMesh Tcl Query Command
This returns a string like <base_name>_ss<ID> where ID is the subsystem ID of the connector.
- id
- The ID of the connector to query.
- base_name
- The base name to append.
Examples
To generate a name for connector 2 and the base "hexa_comp":
hm_ce_generatenamefromsubsystem 2 "hexa_comp"
# Handle error
}Version History
2020
