hm_getmark
Returns the entity IDs of the passed entity type on the specified mark.
hm_getmark entity_type mark_id ?panel_sensitive? ?model_name?
HyperMesh Tcl Query Command
- entity_type
- The type of entity to query.
- mark_id
- The ID of the mark containing the entities. Valid values are 1 and 2.
- panel_sensitive
- Can be used when multiple panel levels have been pushed, either using the shortcut
function keys, or the hm_pushpanel command. This option determines
whether to use the current panel or the previous panel for the operation. This option is
relevant only when the mark has been created from a panel entity selector under the
above conditions. Valid options are:
0 - Use the previous panel (default).
1 - Use the current panel.
- model_name
- The optional model to get the mark for. If not specified, the current model is used.
Examples
hm_getmark comps 1hm_getmark comps 1 0 model-2hm_getmark loads 1 1hm_getmark loads 1 0Errors
# Handle error
}Version History
2020 - Added new option model_name.
