hm_getattachedsolidelemfaces
Returns information about solid elements attached to shell element faces.
hm_getattachedsolidelemfaces entity_type mark_id normal_flag
HyperMesh Tcl Query Command
For a given shell element, this command is used to get the connected solid element ID and the corresponding face index of the solid element. The return list contains, for each input shell element with an attached solid element face the input shell element ID, connected solid element ID and the solid element face index. For example:
{1 20 0} {5 17 4} {3 1 2}
- entity_type
- The type of entity to query. Valid entity types are elems and comps.
- mark_id
- The ID of the mark to query. Valid values are 1 and 2.
- normal_flag
- 0 - Get connected solid element face with normal in the same direction as input shell element normals
To get the attached solid element faces for all displayed elements, using opposite normals:
*createmark elems 1 displayed
set attachedelem_lst [hm_getattachedsolidelemfaces elems 1 1]
# Handle error
}Version History
13.0.110
