hm_linegetorderelems
Get the list of ordered 1D elements associated with input free lines for the given tolerance.
hm_linegetorderelems mark_id ?tolerance?
HyperMesh Tcl Query Command
This command returns a list of lists for the input free edges. The first element of each list is the ID of the free edge and subsequent elements of that list are the IDs of the associated 1D elements.
For example, the output for two orphan edges of IDs 115822 and 115823 with associated 1D elements 8 and 9 is { 115822 8} { 115823 9}
- mark_id
- The ID of the mark of lines. Valid values are 1 and 2.
- tolerance
- The tolerance to compare association of 1D elements with respect to a free line. In the absence of this argument, best associated 1D elements will be returned.
Examples
Find elements for all free lines using a tolerance of 0.5:
*createmark lines 1 all
hm_linegetorderelems 1 0.5
# Handle error
}Version History
2019
