hm_getcrossreferencedentities
Finds entities that reference the specified entity.
hm_getcrossreferencedentities entity_type entity_name_or_id reference_flag output_mark_id string_array number_of_strings ?search_type? ?exclude_regions?
HyperMesh Tcl Query Command
Finds entities that reference the specified entity. This includes collected references, data name references and attribute entity references. Each type of entity that references the specified input entity is returned in a list, and the found entities are then placed on the specified mark for those entity types. See the list of supported entities for this command.
- entity_type
- The type of entity to query.
- entity_name_or_id
- The name or ID of the entity.
- reference_flag
- The type of cross-reference entities to find. Bit values are used and the value is
            calculated as (Bit0 + 2*Bit1 + 4*Bit2). - Bit0
- 0 - Do not consider collected entity cross-references.
 - Bit1
- 0 - Do not consider data name entity cross-references.
 - Bit2
- 0 - Do not consider attribute entity cross-references.
- output_mark_id
- The ID of the mark to place the found cross-referenced entities on. Valid values are 1 and 2.
- string_array
- Reserved for future use. Must be set to 0.
- number_of_strings
- search_type
- By default, HyperMesh searches for entities by name, and if the name is not found, it then searches by ID. This option allows you to specify how the search for an entity should be conducted. Valid values are:
- exclude_regions
- 0 - Include region entities in the search (default).
Examples
To get all entities that cross-reference component with ID 100 on mark 1 and highlight them on the screen:
foreach entity_type [hm_getcrossreferencedentities comps 100 7 1 0 0 -byid] {
    hm_highlightmark $entity_type 1 h
}To get only collected entity cross-references for component with ID 100 on mark 2:
hm_getcrossreferencedentities comps 100 1 2 0 0 -byidTo get only data name entity cross-references for component with ID 100 on mark 1:
hm_getcrossreferencedentities comps 100 2 1 0 0 -byidTo get only attribute entity cross-references for component with ID 100 on mark 1:
hm_getcrossreferencedentities comps 100 4 1 0 0 -byidErrors
   # Handle error
}Version History
10-SA1-130
2019 - Added new optional argument exclude_regions.
