hm_getreplacecomponentpairing
Returns the component pairing for part replacement.
hm_getreplacecomponentpairing existing_component_mark incoming_component_mark pairing_mode
HyperMesh Tcl Query Command
- existing_component_mark
- The ID of the mark containing the existing/old components.
- incoming_component_mark
- The ID of the mark containing the incoming/new components.
- pairing_mode
- Option to define how pairing should be done:
0 - Consider bounding box and collision approach.
1 - Consider matching name of components first and then bounding box and collision approach.
To find the pairing of source comps 301 302 and target comps 503 505:
*createmark comps 1 301 302
*createmark comps 2 503 505
hm_getreplacecomponentpairing 1 2 1
# Handle error
}Version History
2017.2
