*replacesetentitydata
Sets the data required for part replacement.
*replacesetentitydata <option1>=<value1> ?<option2>=<value2>? … ?<optionN>=<valueN>?
HyperMesh Tcl Modify Command
Sets the data required for part replacement. This must precede any calls to *replacentitywithentity or *replacentitywithentitymark.
The input options may be specified in any order.
- componentname=<value>
- The mark ID containing the components to be replaced. Valid values are 1 and 2.
- componentpairstring=<value>
- The list of existing and incoming component name pairs.
- incomingonlyentities=<value>
- The list of entity types that are set as 'accept incoming'.
- preservemark=<value>
- The mark ID for 'accept incoming' entities to be preserved. Valid values are 1 and 2.
To replace components 301 and 302 with 501 and 502 respectively:
*createmark comps 1 301 302
*replacesetentitydata componentmark=1
*createmark sets 1 20 30
*createmark groups 1 20 30
*replacesetentitydata preservemark=1 incomingonlyentities={sets groups} componentpairingstring={{301 501} {302 502}}
*createstringarray 4 "tolerance=0.5" "keep_src_prop=1" "keep_src_mat=1" "keep_src_comp_cardimage=1"
*createmark comps 2 501 502
*replacentitywithentitymark 1 1 2 1 4
# Handle error
}Version History
2017.2
