*newidoption
Defines how new IDs are assigned for a submodel.
*newidoption id option
HyperMesh Tcl Modify Command
This command now new IDs are assigned for a submodel.
- id
- The ID of the submodel.
- option
- 0 - Minimum available
To set the new ID option as using minimum available for include 1:
*newidoption 1 0
# Handle error
}Version History
12.0.110
