*segmentsetcreateusingfacenumber
Creates a segment set using 2D element edges or 2D/3D element faces.
*segmentsetcreateusingfacenumber name color mark_id face_number reverse_normals element_id option
HyperMesh Tcl Modify Command
- name
- The name of the segment set to create.
- color
- The color of the segment set. Valid values are 1-64.
- mark_id
- The ID of the mark containing the elements to use. Valid values are 1 and 2.
- face_number
- The face number of the element (starting from 0).
- reverse_normals
- Create segment set:
- element_id
- If non-zero, specifies the single element to use instead of mark_id. option must be set non-zero.
- option
- If non-zero, specifies to use element_id instead of mark_id.
Examples
*createmark elems 1 1-100
*segmentsetcreateusingfacenumber "test" 5 1 3 0Errors
# Handle error
}Version History
2020
