*writeqiviewsettings
Writes a file containing the element quality view mode settings.
*writeqiviewsettings file
HyperMesh Tcl Modify Command
This command is related to the element quality view mode. It writes the current element quality view settings to a text file that can be read by *readqiviewsettings.
- flag
- The full name and path of the file to save the QI view settings.
To save the current settings to the file C:/settings/qiview.txt:
*writeqiviewsettings "C:/settings/qiview.txt"
# Handle error
}Version History
12.0.110
