*readnodepositionsfromh3dfile
Modes nodes in the current model to positions given in an H3D file.
*readnodepositionsfromh3dfile path
HyperMesh Tcl Modify Command
A valid Radioss model must be loaded.
- path
- The full path and file name of the H3D file.
To read node positions from C:/Users/default/result.h3d:
*readnodepositionsfromh3dfile "C:/Users/default/result.h3d"
# Handle error
}Version History
2017.1
