*surfacemarkremovepinholes
Removes pinholes.
*surfacemarkremovepinholes mark diameter coords arraylength
HyperMesh Tcl Modify Command
Removes pinholes.
- mark
- The mark ID containing the surfaces.
- diameter
- The upper-limit of the pinhole’s diameter.
- coords
- The ID of a double-array listing the center coordinates of the pinholes to remove, in the order x1, y1, z1, x2, y2, z2, x3, y3, z3.
- arraylength
- The array length.
Examples
*createmark(surfaces,1) 471
*createdoublearray(9) 1577.74 500.9 690.69 1580.8 502.6*surfacemarkremovepinholes(1,5,1,12)The *createmark() and *createdoublearray() commands are required.
