*hf_TranslateBinderSurf
Translate the binder along an axis in space. The binder is automatically identified.
*hf_TranslateBinderSurf plane distance
HyperMesh Tcl Modify Command
This command translates the binder along an axis. The direction of translation is given by the plane/vector plane and the magnitude of translation is given by distance.
- plane
- The temporary plane/vector ID created using the *createplane command.
- distance
- Translation distance.
Examples
*createplane 1 0.0000 0.0000 1.0000 0.0000 0.0000 0.0000
*hf_TranslateBinderSurf 1 50*createplane 1 1.0000 0.0000 0.0000 0.0000 0.0000 0.0000
*hf_TranslateBinderSurf 1 -50Errors
# Handle error
}Version History
10.0
